my simple ECU
Posted: Wed Jun 19, 2013 1:30 am
I've been playing with this for some time and finally I have at least something I am not embarrassed to share.
So, my idea is that modern MCUs are fast enough so that a relatively high-level programming would be possible. stm32f4discovery gives me 168MHz for about $15, http://www.chibios.org was the first RTOS I've stumbled upon - this hides most of the lower-level hardware control and even gives me threads.
To begin, at first I was trying to control only fuel or only ignition (with stock ECU controlling the other piece of the puzzle), but soon enough I've realized that I should also control the idle air valve. Crank signal and MAF voltage are currently my only two inputs and I've extracted the fuel map from the stock ECU.
So, currently I control fuel injection and idle. Stock ECU does ignition. This thing starts and I can set idle RPM programmatically.There is still a bug somewhere because things are not super smooth if I push the throttle pedal rapidly, but still
Here it is: https://sourceforge.net/projects/rusefi/
And here is this thing in action: http://www.youtube.com/watch?v=GcxLY697WwM
PS: is there a way to embed video here?
