| Author |
Message |
seank
Joined: Mon Feb 11, 2008 9:52 pm Posts: 304 Location: Arizona
 Re: GCC compiler development for S12X
First bug LOL. Seems some macro adjustments are needed.
seank@mob-sean:~/work/workspaceCDT/binutils-mc9s12x/build-testing/testing/mc9$ make mc9s12x-elf-as --gstabs -o main.o main.s
IN MD_BEGIN
seize of root structure 16 size of opcodes 575
yes -mc9s12x_opcodes[i].arch & current_architecture- is true
number of OPcodes 618 done building table make: *** [main.o] Segmentation fault make: *** Deleting file `main.o'
| Tue Mar 02, 2010 10:16 pm |
Stick to it! :-)
_________________ DIYEFI.org, where Open Source means Open Source, and Free means Freedom Everything in moderation including moderation! http://www.opensource.org/licenses/ My other project (DSL beware) Disclaimer
| Thu Mar 04, 2010 1:44 am |
seank
number of OPcodes 618 should be 599 in s12 mode, but its better than a segfault lol  mc9s12x-elf-as --gstabs -o main.o main.s IN MD_BEGIN seize of root structure 16 size of opcodes 576 Current arch is 4 yes -mc9s12x_opcodes[i].arch & current_architecture- is true, value is 4 number of OPcodes 618 done building table done sorting at end of MD_BEGIN
| Thu Mar 04, 2010 11:19 pm |
seank
Not too shabby............... I need to run a few disasm tests then the fun should start(adding actual xgate stuff). Quote: seank@mob-sean:~/work/workspaceCDT/binutils-mc9s12x/build-testing/testing/hc11$ m68test-elf-readelf test.elf -a ELF Header: Magic: 7f 45 4c 46 01 02 01 00 00 00 00 00 00 00 00 00 Class: ELF32 Data: 2's complement, big endian Version: 1 (current) OS/ABI: UNIX - System V ABI Version: 0 Type: EXEC (Executable file) Machine: Motorola M68HC12 Version: 0x1 Entry point address: 0x0 Start of program headers: 52 (bytes into file) Start of section headers: 4368 (bytes into file) Flags: 0x22 Size of this header: 52 (bytes) Size of program headers: 32 (bytes) Number of program headers: 2 Size of section headers: 40 (bytes) Number of section headers: 8 Section header string table index: 5
Quote: seank@mob-sean:~/work/workspaceCDT/binutils-mc9s12x/build-testing/testing/mc9$ mc9s12x-elf-readelf test.elf -a ELF Header: Magic: 7f 45 4c 46 01 02 01 00 00 00 00 00 00 00 00 00 Class: ELF32 Data: 2's complement, big endian Version: 1 (current) OS/ABI: UNIX - System V ABI Version: 0 Type: EXEC (Executable file) Machine: Freescale S12X Version: 0x1 Entry point address: 0x0 Start of program headers: 52 (bytes into file) Start of section headers: 4368 (bytes into file) Flags: 0x22 Size of this header: 52 (bytes) Size of program headers: 32 (bytes) Number of program headers: 2 Size of section headers: 40 (bytes) Number of section headers: 8 Section header string table index: 5
"Machine: Freescale S12X" I like it
| Mon Mar 08, 2010 6:53 pm |
seank
It seems the clone is working well, the s19 files are the same. seank@mob-sean:~/work/workspaceCDT/binutils-mc9s12x$ time ./patch.sh real 0m37.495s user 0m1.220s sys 0m2.088s "The attachment’s file size is too large, the maximum upload size is 2 MB. Please note this is set in php.ini and cannot be overridden." up the limit Fred  (yeah there was that much code) http://computer-ss.com/files/mc9s12x-3-10-10.patch Now back to it.................
| Wed Mar 10, 2010 5:41 pm |
seank wrote: "The attachment’s file size is too large, the maximum upload size is 2 MB. Please note this is set in php.ini and cannot be overridden." up the limit Fred :) (yeah there was that much code) Nah, get it into github so we can watch your work as it happens ;-) tar balls of code are near useless IMO. You *may* even be able to find a old fork of that version to grab and patch away from? Fred.
| Wed Mar 10, 2010 11:46 pm |
seank
I thought about doing that a while back........ Now that the ball is moving pretty good........... At 118MB its a good thing they upped the limit.
| Thu Mar 11, 2010 1:03 am |
Is that the entire GCC or just the files required for the s12x bit or what? Maybe you can git just a subset of it instead? only if it really really makes sense, though.
| Thu Mar 11, 2010 4:14 am |
seank
GCC is about 350MB untared. Binutils is about 118MB. I suppose at least binutils could be slimmed down a bit by stripping non s12x files out of it and gcc by stripping non C files from it, but that would only set things further back at this point. Good idea though, when we can call it a done job it would be good form.
| Thu Mar 11, 2010 3:02 pm |
seank
Counting objects: 10258, done. Compressing objects: 100% (9873/9873), done. Writing objects: 100% (10258/10258), 23.29 MiB | 136 KiB/s, done. Total 10258 (delta 1291), reused 0 (delta 0) To git@github.com:seank/Binutils-For-FreeScale-s-s12x.git * [new branch] master -> master Not bad at all! http://github.com/seank/Binutils-For-FreeScale-s-s12x
| Thu Mar 11, 2010 3:21 pm |
