I want to get myself some toothed wheel + VR sensor assembly so that I can play without on a bench, without the rest of the engine. I guess that eliminates all the crankshaft wheels / sensors - I do not want the whole small block on the table
Maybe something integrated into the distributor, so that there would be a shaft I can spin by hand and a case? Has to be 80/90s or early 2000s so that I would find it in a junk yard.
Does any car match these criteria?
Examples of missing tooth CAM VR device?
Re: Examples of missing tooth CAM VR device?
Toyota dizzy, but why VR, just use a square wave and bypass your signal conditioner...
- russian
Because I want to test my signal conditionerFred wrote:Toyota dizzy, but why VR, just use a square wave and bypass your signal conditioner...
Something like this 1994 Camry?
Do not see any missing tooth but that does not matter. Thank you for the fast response!
Yep, those are a good test of your circuitry. Why reinvent the wheel?
