Open Source Wideband Display
toalan
Wideband Wizard
Post by toalan »
Hi,
I am making an open wideband display. The project is composed of 2 parts; a driver and a display. The driver is based on an attiny861, the display is based on a 4 digit 7 segment LED display. A ribbon cable connects the display to the driver. The driver gets the AFR signal from the analog 0-5v linear voltage output from your wideband controller.
Display:
Driver
Youtube video
http://www.youtube.com/watch?v=1gRm6s8TN2Q
I will publish the firmware, schematics, and PCB gerber files shortly on my website. I will also sell complete DIY kits with all components for $30.
Regards,
Alan To
toalan
Wideband Wizard
Re: Open Source Wideband Display
Post by toalan »
Firmware, schematic, and gerbers are available here
http://www.14point7.com/Widebands/ADis/ADis.htm
Regards,
Alan To
Did I see a Cube in the background there?
toalan
Wideband Wizard
Post by toalan »
Yup,
Very cool, Alan! As always, you're a legend :-)
WTDeuce
Post by WTDeuce »
How about a version that displays EGT as well? Same idea, 0-5V input just shows EGT in F.
By as well, I mean a different version. I imagine that could just be a firmware change.
WTDeuce wrote:I imagine that could just be a firmware change.
I imagine you are right! :-)
toalan
Wideband Wizard
Post by toalan »
Unfortunately this project is not really expandable as I have used all the pins already on the attiny861 just for the wideband display. This is my first open source project, if all goes well, then I will be looking to do another open source project based on the ATmega88/168/32 that will display AFR/Boost/EGT, datalog to SD card, and do electronic boost control.
Regards,
Alan To
You could definitely do JUST EGT with it with only a firmware swap though, right?
jbelanger
Post by jbelanger »
You'd also need some sort of thermocouple amplifier such as the AD595 to have a 0-5V signal.
Jean
