Re: My 87 toyota supra hardware build
Posted: Sat Jan 04, 2014 10:45 pm
I still haven't had any luck with emstudio giving me valid logs. I specifically set a number of data logs to keep to see if that made a difference. The log directory is filled with files, but the sizes are more or less all the same. I watched one grow and then stop growing at the same size as the rest.
I'll compile it on fedora and see if I do any better.
So in the meantime I have a non-emstudio log. Once I get emstudio logging working it won't continue.
In the log the only sync losses I see are at the beginning and end of cranking. Yesterday I could have sworn the number incremented during cranking, but that hasn't happened yet today. If it does I'll get it.
Is that amount of flutter in the sensors during cranking acceptable?
Also, regarding BRV fluctuations, it is my understanding it are sampled to be able to compensate for changes in battery voltage. However, since all the sensors are powered off 5V switched from the ECU, why is that necessary? It almost seems to me like the sensor deviation flutters the opposite of BRV during cranking. Of course I might be completely wrong and my 5V supply is fluttering too.
Also, cutecom built fine.
EDIT: I totally forgot to attach. Attaching now, along with another one.
-rw-r--r--. 1 via via 0 Dec 15 23:16 2013.12.15-23.16.03.bin
-rw-r--r--. 1 via via 651 Dec 15 23:16 2013.12.15-23.16.03.both.bin
-rw-r--r--. 1 via via 388 Dec 15 23:16 2013.12.15-23.16.03.meta.json
-rw-r--r--. 1 via via 651 Dec 15 23:16 2013.12.15-23.16.03.toecu.bin
-rw-r--r--. 1 via via 0 Dec 16 00:07 2013.12.16-00.07.09.bin
-rw-r--r--. 1 via via 651 Dec 16 00:07 2013.12.16-00.07.09.both.bin
-rw-r--r--. 1 via via 388 Dec 16 00:07 2013.12.16-00.07.09.meta.json
-rw-r--r--. 1 via via 651 Dec 16 00:07 2013.12.16-00.07.09.toecu.bin
-rw-r--r--. 1 via via 0 Dec 16 00:09 2013.12.16-00.09.26.bin
-rw-r--r--. 1 via via 651 Dec 16 00:09 2013.12.16-00.09.26.both.bin
-rw-r--r--. 1 via via 388 Dec 16 00:09 2013.12.16-00.09.26.meta.json
-rw-r--r--. 1 via via 651 Dec 16 00:09 2013.12.16-00.09.26.toecu.bin
-rw-r--r--. 1 via via 0 Dec 16 00:11 2013.12.16-00.11.44.bin
-rw-r--r--. 1 via via 651 Dec 16 00:12 2013.12.16-00.11.44.both.bin
-rw-r--r--. 1 via via 388 Dec 16 00:11 2013.12.16-00.11.44.meta.json
-rw-r--r--. 1 via via 651 Dec 16 00:12 2013.12.16-00.11.44.toecu.bin
-rw-r--r--. 1 via via 0 Dec 16 20:49 2013.12.16-20.49.39.bin
-rw-r--r--. 1 via via 651 Dec 16 20:50 2013.12.16-20.49.39.both.bin
-rw-r--r--. 1 via via 388 Dec 16 20:49 2013.12.16-20.49.39.meta.json
-rw-r--r--. 1 via via 651 Dec 16 20:50 2013.12.16-20.49.39.toecu.bin
-rw-r--r--. 1 via via 0 Dec 18 22:16 2013.12.18-22.16.27.bin
-rw-r--r--. 1 via via 651 Dec 18 22:17 2013.12.18-22.16.27.both.bin
-rw-r--r--. 1 via via 388 Dec 18 22:16 2013.12.18-22.16.27.meta.json
-rw-r--r--. 1 via via 651 Dec 18 22:17 2013.12.18-22.16.27.toecu.bin
-rw-r--r--. 1 via via 0 Dec 19 22:36 2013.12.19-22.36.55.bin
-rw-r--r--. 1 via via 1.3K Dec 19 22:37 2013.12.19-22.36.55.both.bin
-rw-r--r--. 1 via via 388 Dec 19 22:37 2013.12.19-22.36.55.meta.json
-rw-r--r--. 1 via via 1.3K Dec 19 22:37 2013.12.19-22.36.55.toecu.bin
-rw-r--r--. 1 via via 0 Dec 19 23:02 2013.12.19-23.02.23.bin
-rw-r--r--. 1 via via 651 Dec 19 23:02 2013.12.19-23.02.23.both.bin
-rw-r--r--. 1 via via 388 Dec 19 23:02 2013.12.19-23.02.23.meta.json
-rw-r--r--. 1 via via 651 Dec 19 23:02 2013.12.19-23.02.23.toecu.bin
-rw-r--r--. 1 via via 0 Dec 19 23:19 2013.12.19-23.19.10.bin
-rw-r--r--. 1 via via 659 Dec 19 23:19 2013.12.19-23.19.10.both.bin
-rw-r--r--. 1 via via 388 Dec 19 23:19 2013.12.19-23.19.10.meta.json
-rw-r--r--. 1 via via 659 Dec 19 23:19 2013.12.19-23.19.10.toecu.bin
-rw-r--r--. 1 via via 0 Dec 20 20:40 2013.12.20-20.40.39.bin
-rw-r--r--. 1 via via 651 Dec 20 20:41 2013.12.20-20.40.39.both.bin
-rw-r--r--. 1 via via 388 Dec 20 20:40 2013.12.20-20.40.39.meta.json
-rw-r--r--. 1 via via 651 Dec 20 20:41 2013.12.20-20.40.39.toecu.bin
-rw-r--r--. 1 via via 0 Dec 20 20:44 2013.12.20-20.44.24.bin
-rw-r--r--. 1 via via 651 Dec 20 20:44 2013.12.20-20.44.24.both.bin
-rw-r--r--. 1 via via 388 Dec 20 20:44 2013.12.20-20.44.24.meta.json
-rw-r--r--. 1 via via 651 Dec 20 20:44 2013.12.20-20.44.24.toecu.bin
-rw-r--r--. 1 via via 0 Dec 20 22:06 2013.12.20-22.06.09.bin
-rw-r--r--. 1 via via 683 Dec 20 22:06 2013.12.20-22.06.09.both.bin
-rw-r--r--. 1 via via 388 Dec 20 22:06 2013.12.20-22.06.09.meta.json
-rw-r--r--. 1 via via 683 Dec 20 22:06 2013.12.20-22.06.09.toecu.bin
-rw-r--r--. 1 via via 0 Dec 23 23:05 2013.12.23-23.05.35.bin
-rw-r--r--. 1 via via 694 Dec 23 23:06 2013.12.23-23.05.35.both.bin
-rw-r--r--. 1 via via 388 Dec 23 23:05 2013.12.23-23.05.35.meta.json
-rw-r--r--. 1 via via 694 Dec 23 23:06 2013.12.23-23.05.35.toecu.bin
-rw-r--r--. 1 via via 0 Dec 24 01:06 2013.12.24-01.06.40.bin
-rw-r--r--. 1 via via 651 Dec 24 01:07 2013.12.24-01.06.40.both.bin
-rw-r--r--. 1 via via 389 Dec 24 01:06 2013.12.24-01.06.40.meta.json
-rw-r--r--. 1 via via 651 Dec 24 01:07 2013.12.24-01.06.40.toecu.bin
-rw-r--r--. 1 via via 0 Dec 24 01:35 2013.12.24-01.35.08.bin
-rw-r--r--. 1 via via 651 Dec 24 01:35 2013.12.24-01.35.08.both.bin
-rw-r--r--. 1 via via 389 Dec 24 01:35 2013.12.24-01.35.08.meta.json
-rw-r--r--. 1 via via 651 Dec 24 01:35 2013.12.24-01.35.08.toecu.bin
-rw-r--r--. 1 via via 0 Dec 26 20:54 2013.12.26-20.54.33.bin
-rw-r--r--. 1 via via 651 Dec 26 20:55 2013.12.26-20.54.33.both.bin
-rw-r--r--. 1 via via 389 Dec 26 20:54 2013.12.26-20.54.33.meta.json
-rw-r--r--. 1 via via 651 Dec 26 20:55 2013.12.26-20.54.33.toecu.bin
-rw-r--r--. 1 via via 0 Dec 26 23:19 2013.12.26-23.19.39.bin
-rw-r--r--. 1 via via 885 Dec 26 23:25 2013.12.26-23.19.39.both.bin
-rw-r--r--. 1 via via 389 Dec 26 23:19 2013.12.26-23.19.39.meta.json
-rw-r--r--. 1 via via 885 Dec 26 23:25 2013.12.26-23.19.39.toecu.bin
-rw-r--r--. 1 via via 0 Dec 26 23:26 2013.12.26-23.26.43.bin
-rw-r--r--. 1 via via 815 Dec 27 17:55 2013.12.26-23.26.43.both.bin
-rw-r--r--. 1 via via 389 Dec 26 23:26 2013.12.26-23.26.43.meta.json
-rw-r--r--. 1 via via 815 Dec 27 17:55 2013.12.26-23.26.43.toecu.bin
-rw-r--r--. 1 via via 0 Dec 27 18:21 2013.12.27-18.21.08.bin
-rw-r--r--. 1 via via 897 Dec 27 19:14 2013.12.27-18.21.08.both.bin
-rw-r--r--. 1 via via 389 Dec 27 18:21 2013.12.27-18.21.08.meta.json
-rw-r--r--. 1 via via 897 Dec 27 19:14 2013.12.27-18.21.08.toecu.bin
-rw-r--r--. 1 via via 0 Dec 27 19:20 2013.12.27-19.20.50.bin
-rw-r--r--. 1 via via 701 Dec 27 19:25 2013.12.27-19.20.50.both.bin
-rw-r--r--. 1 via via 389 Dec 27 19:20 2013.12.27-19.20.50.meta.json
-rw-r--r--. 1 via via 701 Dec 27 19:25 2013.12.27-19.20.50.toecu.bin
-rw-r--r--. 1 via via 0 Dec 27 19:29 2013.12.27-19.29.43.bin
-rw-r--r--. 1 via via 651 Dec 27 19:30 2013.12.27-19.29.43.both.bin
-rw-r--r--. 1 via via 389 Dec 27 19:29 2013.12.27-19.29.43.meta.json
-rw-r--r--. 1 via via 651 Dec 27 19:30 2013.12.27-19.29.43.toecu.bin
-rw-r--r--. 1 via via 0 Dec 28 02:43 2013.12.28-02.43.25.bin
-rw-r--r--. 1 via via 1.7K Dec 28 02:59 2013.12.28-02.43.25.both.bin
-rw-r--r--. 1 via via 389 Dec 28 02:43 2013.12.28-02.43.25.meta.json
-rw-r--r--. 1 via via 1.7K Dec 28 02:59 2013.12.28-02.43.25.toecu.bin
-rw-r--r--. 1 via via 0 Dec 29 03:12 2013.12.29-03.12.29.bin
-rw-r--r--. 1 via via 651 Dec 29 03:13 2013.12.29-03.12.29.both.bin
-rw-r--r--. 1 via via 389 Dec 29 03:12 2013.12.29-03.12.29.meta.json
-rw-r--r--. 1 via via 651 Dec 29 03:13 2013.12.29-03.12.29.toecu.bin
-rw-r--r--. 1 via via 0 Jan 2 14:20 2014.01.02-14.20.33.bin
-rw-r--r--. 1 via via 651 Jan 2 14:21 2014.01.02-14.20.33.both.bin
-rw-r--r--. 1 via via 390 Jan 2 14:20 2014.01.02-14.20.33.meta.json
-rw-r--r--. 1 via via 651 Jan 2 14:21 2014.01.02-14.20.33.toecu.bin
-rw-r--r--. 1 via via 0 Jan 2 17:22 2014.01.02-17.21.48.bin
-rw-r--r--. 1 via via 651 Jan 2 17:22 2014.01.02-17.21.48.both.bin
-rw-r--r--. 1 via via 390 Jan 2 17:22 2014.01.02-17.21.48.meta.json
-rw-r--r--. 1 via via 651 Jan 2 17:22 2014.01.02-17.21.48.toecu.bin
-rw-r--r--. 1 via via 0 Jan 3 18:25 2014.01.03-18.25.51.bin
-rw-r--r--. 1 via via 651 Jan 3 18:26 2014.01.03-18.25.51.both.bin
-rw-r--r--. 1 via via 390 Jan 3 18:26 2014.01.03-18.25.51.meta.json
-rw-r--r--. 1 via via 651 Jan 3 18:26 2014.01.03-18.25.51.toecu.bin
-rw-r--r--. 1 via via 0 Jan 3 18:36 2014.01.03-18.36.31.bin
-rw-r--r--. 1 via via 651 Jan 3 18:37 2014.01.03-18.36.31.both.bin
-rw-r--r--. 1 via via 386 Jan 3 18:36 2014.01.03-18.36.31.meta.json
-rw-r--r--. 1 via via 651 Jan 3 18:37 2014.01.03-18.36.31.toecu.bin
-rw-r--r--. 1 via via 0 Jan 3 18:45 2014.01.03-18.45.38.bin
-rw-r--r--. 1 via via 651 Jan 3 18:46 2014.01.03-18.45.38.both.bin
-rw-r--r--. 1 via via 386 Jan 3 18:45 2014.01.03-18.45.38.meta.json
-rw-r--r--. 1 via via 651 Jan 3 18:46 2014.01.03-18.45.38.toecu.bin
