Re: Ion Sensing ideas and circuit designs
Posted: Sun Nov 02, 2008 7:33 pm
The ionic current flow will be there at all times even in free air but to a very small degree probably not even measurable by our front end.
During compression the number of molecules per unit volume increases as the mixture is squashed into a much smaller space there fore the gap between the plugs gets more conductive and more electrons are able to hop from molecule to molecule and reach the opposite electrode.
just after ignition the current flow will be a virtual short for a brief moment as the current will be flowing through plasma which is really conductive.
the exhaust gases left behind are also conductive to a degree and just like the rise of pressure during compression the rise in pressure because of the expanding gases crams more molecules closer together therefore more ionic current flows.
When the PPP (peak pressure point) is reached, which should be perfectly timed to extract as much mechanical effort out of the burn as possible (minus Fred's safety margin) thats where the advance table comes into play, to perfectly align expanding gas with optimum crank angle. thats what I cocked up with MS2.
Anyway the basics of it are there is always ionic current flow throughout the whole cycle.
